Hi Folks,
Over the past week or so my Corolla TS (2002) has had a problem with the Alarm going off for no reason. Now iv just done a quick search around and found the info regarding the pressure switch under the bonnet which i'll have a little crack at tomorrow.
One thing that is bugging me about this however, is the alarm goes off seriously on time, everyday at 8.30am! so much so that i now have my phone alarm set to 8.20am so i can go and stand at the kitchen window ready to knock it off with the remote, then, it is fine all day. doing this has also ruled out the chance of say someone going to work at the time and activating it, someone just fooling around etc
would anyone be aware why the system would have some kind of a 24hour timeout? because honestly it is perfect timing! problem even persists regardles of when the car was last used etc
all being well the pressure sensor mod will cure things, but think this is worth a ponder in the meantime.
cheers in advance fella's
Page 1 of 1
Alarm Problem Pain in the A**!
#4
Posted 15 March 2010 - 01:03 PM
I had the same problem,
I tried taping the bonnet sensor down, to eliminate it before i went bending any brackets or anything. The alarm still went off.
Took it to toyota, half an hour later and it was fixed.
all they would tell me was a sensor needed adjusting. There were oily finger marks around the interior light fitting, so im guessing there was something under there that they adjusted
#6
Posted 15 March 2010 - 02:31 PM
Cheers for the heads up and info guys had'nt come accross that manual so downlaoded a copy
done the little mod, just no nailed a 5mm thick piece of fibre board to the bonnet so the sensor sits onto that, hopefully wont be getting that second alarm call tommorow haha!
really does make sense about the expansion, i only bought the car at the begininng of november so to be honest up until this past 2 weeks or so its done nothing but drive in arctic weather. so all being well this'll crack it.
#12
Posted 20 March 2010 - 03:19 PM
I now have this problem, it's not the clock though because it is just doing it when it pleases.
I'll have a look under the bonnet and check the sensor.
Bloody irritating, I would complain that it's too sensitive but tbh that;s just a sign that Toyota want to keep your car safe!
Page 1 of 1
MultiQuote
