Headunit Fitting (take Two).
Chappers
Fascia Surround: T55406-52010-B0 is for the Phase 1 (roughly £38)
Fascia Surround: T55406-52041-B0 is for the Phase 2 (roughly £38)
Double Din Unit - FP-11-03, made by Audioleads, it says for a RAV4 but it will fit the Yaris - from Halfords
ISO lead: PC2-17-4 (toyota one)...... £12 Halfords
Picture WITH Fascia Surround..
Picture WITHOUT Fascia Surround (Head Unit placed inside coin tray...
And with regards to fitting, there are many links to follow in the How To's
For fitting the adapter..
Simply insert headunit and cage into the appropriate slot, and bend the security prongs up on the top and sides (see pic)..
The adapter is then held in place by three self tappers.. Two at the top left and right hansdside corners. and one at the bottom left. (Note that I left the additional 'legs' on to avoid any 'Oops I've snapped off the wrong one because the Instructions said to' disaster.. Simply insert the adapter and line up the holes. Screw in and secure..
Sorted... :thumbsup:
Thank god someone's actually put this altogether now! Saves having to look around for it all the time. Perhaps it should be stickied???
it doesnt look stong, it looks like snapable plastic
You snap the legs off that you do not require..
Sorry it's not made of lightweight alloy, plastic snaps..
Chappers! You have a CDA-9812RB! You god!
Is it the best thing ever? I want one soooo badly. The specs seem superb for the price.
:yes: .. For what I paid aswell ;) , I can't fault it.. Sub out - well you've read the spec's.. Unless you plan on entering SPL competitions you can't go wrong. :thumbsup:
I agree! Thanks again. :thumbsup:
cheers chappers i understands now its that ive got them tabs you bolt through snapped off by the guy i bought mine off damn him ill have to bodge mine or get a new one now,
cheers
Lee
is the hairy leg a must?
Get's 'SoToc' going ;)
yes the leg worked :D its pinned for you,
rob will move it into his how toos to!
This topic is now closed to further replies.
