I have a 3.0 v6 Camt, which has all of sudden lost power. I have had it checked by a garage who put it on the computer to see the fault, he said that it was showing cylinder 1 as having low compression. He did a compression test and found everything to be ok. He changed the ignition coils around to see if the fault followed a coil. But the fault saw still showing the same as cyclinder 1 having low compression. Any ideas?
Thank You in advance
