Help - Search - Members - Calendar
Full Version: Fan Heater Problem Or Not?
Toyota Owners Club - Toyota Forum > Toyota Forums > Toyota Landcruiser
chocky14u
Am i missing something.....
When idling the LC4 no heat only cool air will come from the heating ducts; warm air being especially useful when demisting the front windscreen prior to moving off.
When 1000 rpm is reached miraculously the heat comes from the ducts to demist the windscreen.
Our local Toyota dealer today has stated that there is no fault (probably after plugging in some ecu lead)
Are they right?
Do other users suffer the same problem?
I use other LC4's regular and have not noticed this problem before...
igormus
QUOTE (chocky14u @ Oct 6 2009, 05:57 PM) *
Are they right?
hello mate
sometimes it si not anough to switch ON the fan only but it is recomended to swith an A/C compressoro ON and all the moisture will be obsorbed on the evaporator -- this works perfectly especially when outside air is too must wet.
Cheers/Igor
chocky14u
QUOTE (igormus @ Oct 8 2009, 12:53 PM) *
Are they right?
hello mate
Cheers/Igor
thanks igor..
Can confirm that the A/C button automatically switches on when the front window demist button is swiched on, no heat with it either switched on or off..baffled two factory technicians.......Toyota garage confirmed today that they could find no fault.........We shall see when UK winter throws its finest at us.
cheers
Martin.
igormus
QUOTE (chocky14u @ Oct 8 2009, 03:28 PM) *
Are they right?
hello mate
Cheers/Igor
thanks igor..
cheers
Martin.
Martin
Hi
Is your thermostat in order?
Does coolant themp reach normal ranges when drived?
It still not clear.
Cheers/Igor
chocky14u
QUOTE (igormus @ Oct 9 2009, 07:01 AM) *
Are they right?
hello mate
Cheers/Igor
thanks igor..
cheers
Martin.
Martin
Hi
It still not clear.
Cheers/Igor
Yes thermostat works fine, temperature guage ok, heat emits from vents ok above 1000rpm as it should it's just that when idling no heat; as tho a cut off valve is not opening Toyota dealer plugged in his magic plugs all ok deemed the puzzled technicians. Dealer has written down on their computer record concern over heater before vehicle warranty runs out. to return to dealer for further investigation.
Been running an identical lc4 model today at work and controls in exactly the same setup.....heater working on idle got me puzzled too!!!
Andy
I would say that the heater matrix needs a good flush out, then make sure you dont have any air locks in the system.
igormus
QUOTE (chocky14u @ Oct 9 2009, 05:50 PM) *
Are they right?
hello mate
Cheers/Igor
thanks igor..
cheers
Martin.
Martin
Hi
It still not clear.
Cheers/Igor
hi
have coolant system investigated + check coolant level. it really looks strange that the engine gives no heat to feel even small heat in the saloon.
but i ve heard the similar issue in the rav's dept and those explanation was that the mordern diesels are very economical and give no much heat when idled --may be this is the case.
Cheers/Igor
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
