Help - Search - Members - Calendar
Full Version: Engine Whine
Toyota Owners Club - Toyota Forum > Toyota Forums > Toyota Landcruiser
300kk
I have just bought an 03 petrol LC4. There is a whine which is present from start-up, whether the car is in neutral, park or reverse. The pitch of the whine rises and drops with the rpm and never goes away. It doesn't seem to change when turning the steering wheel, and there is no difference when the air con is on/off.
I was thinking this might be an idler pulley, but would welcome any ideas. More importantly, is it OK to keep driving it?
300kk
Any ideas? Anyone?
Would really appreciate any suggestions before I go to a garage and end up spending a fortune. sick.gif
sandgroper
QUOTE (300kk @ Oct 21 2009, 07:55 PM) *
Any ideas? Anyone?
I dont know what an LC4 is,Im guessing its either a 100 series Landcruiser or a 120 series Prado.
With those annoying whining sounds from the front,I get a can of belt spray and spray the hoses. This will quieten everything down for a few mins and make it easier to diagnose.
You can also spray the pulleys and idler as this will temporarily lubricate a bad bearing or bush and make the noise stop
The next step is to temporarily detach the belts one by one,and when the noise stops,the problem is with one of the pulleys or idler on that belt.
Obviously you cannot remove the timing belt and I suspect you probably have one large belt that does everything .
Its probably ok to keep driving until the noise changes to a lower pitch
Also feel for signs of heat from the pulleys or idler
300kk
Thank you, I'll give that a go
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
