QUOTE (paulnanrod @ Oct 29 2009, 09:22 AM)
I have a Rav4 Freesport and have a couple of questions.......It has covered 83k miles, and there are a couple of problems....
First - the rear washer jet doesn't work. When the stalk is turned to use the washer jet, water gushes out from around the reservoir area......How do I get to this? I can't seem to get in from the bonnet - is it a case of going in the wheel arch?
Next - when the car is jacked up, the wheel touches the floor still......my guess would be a puncture would be impossible to repair. Is this normal, or could there be something up with my suspension?
Last - I have a juddering steering wheel! Only when at 70 mph ish this starts to judder.....any ideas what this could be.
I know all of the above are probably covered off easily by saying it's an old car and with them comes problems, but I want to try and keep it going, so was looking for some help if anyone had ideas!
The cars just a youngster.
Rear washer - never had a problem with that - just try to trace back where the water is coming from?? Altho the bottle is into the arch I'd have guessed that the pipework will come out near the top?
The suspension has a lot of travel - remember the first RAVs were built to be soft off-roaders not like the beasts built nowadays. I never trust scissor type jacks and bought a small trolley jack which you can place under the trailing arm at the back or the base of the strut up front....then you just jack up the wheel.
Juddering steering wheel - if its when driving and NOT braking then its wheel balance. If its when braking then its more likely to need the front discs skimmed very slightly. On a car that age, I'd think about getting the wheels aligned by the laser method too.
I have 2 RAVS - one with 80,000 miles and 1 I use for racing which has more than 170,000 miles on the clock - and both are 1994 models.
