NADP555
October 29, 2009, 11:41 am
I purchased my Auris T180 over 12months ago .It is on a 07 plate. I am having no end of trouble with the alarm going off on it for no reason at all. Been back a number of times to the garage who tell me they cannot find a fault code error. They have changed various sensors but still have the problem. They asked if I had mobile phones in the car or anything electrical. I haven't. They thought it might be radio interference by mobile phone masts or electric fence on a nearby farm. Again this is not the case as it happens away from home and not in one location. They really have not got a clue. Obvious things like Windows,Sun roof closed, door shut properly,nothing hanging in car..all checked.
They have changed the key fobs & reprogrammed it to another frequency. but still no joy.
You can shake the car and the alarm will not go off, so it is not wind,motion sensor.
We also had "Check Air Bag" come up from time to time then go out. Every time I take it back to the garage,they could find no fault or fault code stored.
This week when it came on again and I drove straight to the garage and did not turn the car off. They found a fault with a sensor under the seat, and told me this could also be related to the alarm problem!
Two days after having the car back at 6.24am. this morning,the alarm went off again!
I phoned the garage, the manager who told me what they had found earlier this week was away on holiday,so I spoke to another person who told me some thing entirely different. He said they had found a fault with the microphone sensor in the car and had de-sensortised it. As it is still going off, they said they will order a new one! Different to what i had been told by the manager.
I did find on the forum a posting dated last Nov of someone with an alarm fault on an Auris. At the time I had not registered on the forum. Went away to register,but can't now find the posting.........Any help in any direction, will be appreciated. Thanks..
T Sport 1978
October 30, 2009, 8:51 pm
Not really going to help with this but i dont believe alarm on the T180 is known to be troublesome, I have not seen anything here that suggests otherwise. Never had any problems with mine although it went off once when a kid kicked a stone which hit the underside of my car and it went off, I thought that was impressive!
tccom
November 7, 2009, 8:52 pm
[quote name='NADP555' post='940240' date='Oct 29 2009, 11:41 AM']I purchased my Auris T180 over 12months ago .It is on a 07 plate. I am having no end of trouble with the alarm going off on it for no reason at all. Been back a number of times to the garage who tell me they cannot find a fault code error. They have changed various sensors but still have the problem. They asked if I had mobile phones in the car or anything electrical. I haven't. They thought it might be radio interference by mobile phone masts or electric fence on a nearby farm. Again this is not the case as it happens away from home and not in one location. They really have not got a clue. Obvious things like Windows,Sun roof closed, door shut properly,nothing hanging in car..all checked.
I did find on the forum a posting dated last Nov of someone with an alarm fault on an Auris. At the time I had not registered on the forum. Went away to register,but can't now find the posting.........Any help in any direction, will be appreciated. Thanks..[/quote]
may be same set up as the corolla? under bonnet switch see if the tab on the bonnet is fully pressing down on the switch if not adjust the tab to fully close the switch,just a thought.
PhilGee
November 9, 2009, 12:45 pm
Another thing with the bonnet switch, because of the position, just check there is no corrosion or water ingress into the micro switch. Trouble with checking for faults on alarms through the onboard diagnostics is that the system might not see it as a fault, but a geniune reason to sound alarm.
Keep us posted
NADP555
November 9, 2009, 9:07 pm
Thanks for input guys. Still waiting for garage to say mcrophone sensor has come in they are supposed to have ordered. To date the alarm has not gone off again..Thats the power of the forum!! Let you know what they fit and when and the outcome..
Jamesbelfast
November 9, 2009, 9:19 pm
Most car alarms rely on a voltage drop in their electrics to activate the system so any electrical fault in a system which is still active when the car is parked can trigger the system - even water ingress to some areas can cause similar symptoms. Try shaking the doors, bonnet and boot lid to see if anything happens - if so that would denote a switch problem. If you suspect an interior volumetric sensor to be at fault sticking a piece of good old duct tape over them can prevent them from activating although remember this may invalidate your insurance should the worse happen. Sometimes it a case of elimating each sensor or switch in turn.
tspirit888
November 10, 2009, 10:09 pm
[quote name='Jamesbelfast' post='943380' date='Nov 9 2009, 09:19 PM']Most car alarms rely on a voltage drop in their electrics to activate the system so any electrical fault in a system which is still active when the car is parked can trigger the system - even water ingress to some areas can cause similar symptoms. Try shaking the doors, bonnet and boot lid to see if anything happens - if so that would denote a switch problem. If you suspect an interior volumetric sensor to be at fault sticking a piece of good old duct tape over them can prevent them from activating although remember this may invalidate your insurance should the worse happen. Sometimes it a case of elimating each sensor or switch in turn.
[/quote]
any tech in mrT,s garages will be able to plug in their tester and identify the fault clearly
also microphone sensors are a fairly common fault on t180 and verso models
NADP555
November 12, 2009, 8:55 pm
Thanks for comments & Advice. Still waiting for garage to get back to me when the part comes in. Don't want to compromise security of vehicle and should not have to on a vehicle under warranty. So hope the garage can finally fix it. Again when I do hear news , will keep you all posted.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
