leggyloo2
Nov 1 2009, 09:31 PM
Hello, can anybody please help. I have a rav4 manual, 2.0 litre ingection, GX, 3sfe. The engine needed to be replaced so I have spent the last week putting in a replacement 3sfe engine from a 1997 rav4. The engine is running great but since replacing it, on starting her up for the 1st time there was an intermittent buzzer noise which I have found out is to tell me the diff lock is on (the diff lock button is not pressed in or lit up). If i press the diff lock button in, to the on position the buzzer stops, I'd hoped the hoses were just fastened up the wrong way round but after slowley reversing out of my drive then back in, I can feel that the diff lock is on. it wont come off. ive found the vacum pipe & undone this & i can hear air so this is working. one thing is concerning me & that is when I replaced the engine, gearbox, transfer box etc there was a bracket that slightly bent. i managed to straighten it when replaciing everything & i think this bracket is the diff lock arm that is now stuck & not disengaging. as anybody got any advise. I cant think of how I can get the diff back out without removing the engine again. im not that bothered about having the diff lock & i wondered if anybody knew if it was possible to remove the propshaft & use the rav4 as a 2 wheel front drive only. if anybody knows how i can unstick the diff lock, id really appreciate. im doing the engine replacement on a tight budget & to now have a new engine in, thats running as sweet as a nut but still not been able to use my rav - due to a probelm that wasnt there before i started is reeally frustrating.....please any advise would be great...thanks.......
Laura
anchorman
Nov 1 2009, 09:42 PM
Hello Laura and welcome to the club.
The diff lock doesn't work quite like you might think in that the buzzer works when you disengage it and not the other way around. When you engage it an electro pneumatic switch allows vacuum to suck the diff lock into engagement so when you switch it off atmospheric pressure disengages it. However, it is not uncommon for them to stick and in that case when the vacuum is released but the diff doesn't disengage, the buzzer sounds as a warning. In that case you slowly reverse the car and the diff lock will drop out of engagement. Try it first and then report back.
mrbilly
Nov 1 2009, 09:44 PM
check all of the pipes for enough vacuum there might just be a leak possibly from pinching a pipe on installation
leggyloo2
Nov 1 2009, 10:36 PM
QUOTE (anchorman @ Nov 1 2009, 09:42 PM)
Hello Anchorman thanks for the quick reply. Ive tried to reverse the car & the diff lock is still not disengaging. I can feel its still on when i drive. if i go backwards & forwards its ok, if i turn the steering wheel its stiffening up, as though the breaks are on & the buzzer is buzzing all the time. if i press the diff lock buzzer to on, it stops buzzing (beeping). could i have damaged something. when i pulled the engine & gearbox apart the tie bar from the engine to the inlet manifold slightly pulled back the servo that operates the diff lock. when i pushed the servo back into position it seemed to be a lot harder than it should have been to push back. this is concerning me & im thinking i could have damaged something...??? any ideas...?? thanks
leggyloo2
Nov 1 2009, 11:14 PM
QUOTE (mrbilly @ Nov 1 2009, 09:44 PM)
hi thanks for your reply. ive checked the pipes to the top of the engine & when i pull the top of the pipe off i can hear air comming out. is there a way of getting to the diff lock without having to take the engine back out..??? ive just spent 5 days taking the old engine out & putting the new one in, its something i really dont want to have to do again. i would have thought though if there was a leak in the pipes that when i take the top off the pipe from under the bonnet that i wouldnt be able to hear the air that comes out.... would you agree...??
mrbilly
Nov 1 2009, 11:35 PM
when the engine is running you should no hear air coming out of somewhere
when you switch on the diff lock you dont hear much but when you turn it off you just hear a scchhhhh sound as it allows the vacuum to release to atmosphere.
it basically has another brake booster to hold the vacuum from which you can see from the drivers side wheel arch there should be vacuum pipes coming off this
leggyloo2
Nov 2 2009, 01:18 AM
QUOTE (mrbilly @ Nov 1 2009, 11:35 PM)
When I start the car the beep starts this is b4 I press the diff lock button. If I press the diff lock button the beep stops. I cant hear any air. Its only when I lift the bonnet + un do the vacum pipe that I can hear the suction. All pipes r connected when I look threw driver wheel arch. Please read both my threads to anchorman when ive explained whats gone wrong + let me know what u think. Im worried ive damaged sumthing while I was replacin engine as this problem came on 1st start when the engine was replaced. Please read what I did + let me no your thoughts. I realy need sum help. Do u think its poss to remove the propshaft to rear wheels + av just front wheel drive as a temp fix so I can drive my rav..? Thanks
mrbilly
Nov 2 2009, 07:47 AM
ok the problem is possibly the two vsv switches may have thier vac piping the wrong way round, removing the propshaft is something i would not do. i think the vsvs are on the firewall near the clutch fluid
anchorman
Nov 2 2009, 08:58 AM
The diff lock is spring loaded so with all the vac pipes off there should be no way it can be held into engagement. If you take the rear prop off it is still engaged in the box and TBH I wouldn't like to speculate on the affect of all those bits continuously whizzing round. It might be OK but I wouldn't like you to cook it. I tend to think when you pushed that vac unit back in you have just put enough strain on it to hold it engaged. If I were in your shoes I wouldn't risk it (I'd probably get strange looks as well) but my point is that at the moment it stands you at taking it out again but if you do fry that diff lock you're going to need a new transmission and the labour.
leggyloo2
Nov 2 2009, 10:07 AM
QUOTE (anchorman @ Nov 2 2009, 08:58 AM)
thanks again for your help & i do understand what your saying about the diff lock. im just so annoyed with myself for pushing the vac unit back in the way i did, i shouldnt have done that but hey its done now & ive to solve the problem. ive taken all the vac pipes off, ive gone underneath & tried to pull the diff lock & its going nowhere, it just wont move. im going to go have another look when i get in from work this afternoon & make sure that everything is definitley off but ive got an awful feeling the engine is going to have to come back out. ill let you knwo how it goes, thanks again Laura
leggyloo2
Nov 2 2009, 08:54 PM
QUOTE (leggyloo2 @ Nov 2 2009, 10:07 AM)
Ok just spent a bit of time tryin to solve my diff lock problem + I just wondered, when the diff lock is in position does it just rely on the vacum to hold it in place or is there anything else that holds it in.??? The reason I ask is ive just taken every pipe off + its still stuck on. Im realy sorry to be a pain but ive never seen inside a diff lock servo so I dont know what mechanisms are in there so im workin blind. When the switch is off theres no vacum from the 2 actuators on the bulk head + when I put the diff lock button to on the actuators are creatin a vacum. All the pipes are marked + coupled up exactly as they were before I changed the engine + the diff lock was workin ok then, but sumthing is still not allowin it to disengage. I cant figure out what it is. Ive even been underneath the rav + manualy tried to move the pin that goes between the servo + the diff whilst rockin the wheels. It will move about 1/2 inch in + out but still wont disengage. As anyone any ideas or as anyone got a diagram or able to up-load a sketch of how the lockin mechanism works before I go mad. I need to get sum kip but I cant as this is driving me round the bend. I cant figure out why its unable to disengage when all seems to be workin ok. Thanks laura
bothwell_buyer
Nov 2 2009, 11:26 PM
QUOTE (leggyloo2 @ Nov 2 2009, 09:54 PM)
Phone up the guys that have done my 1994 RAVs - and ask to speak to Dennis. He has done all the development work on my 2 race cars and both have the original gearbox...and I know he will have a good idea of what you need to look for.... the number is 01698 265303 and say to Becky that big Ian will cover off the cost of advice for you. Marc owns and runs the joint but Dennis did the business - Marc knows a shed load of info on the car as well - they got the cars up to 300bhp+ and have just fitted a new racing clutch to 1 RAV. They have my other RAV in cos the gearbox speedo drive broke so they will have that apart this week.
leggyloo2
Nov 3 2009, 12:02 AM
QUOTE (bothwell_buyer @ Nov 2 2009, 11:26 PM)
johnjnam
Nov 3 2009, 05:39 AM
QUOTE (leggyloo2 @ Nov 2 2009, 10:54 PM)
Hi Leggyloo
Join the club- I am just as fustrated as you are trying to get information regarding the gearboxes and central diffs of the Rav . It must be a real piece of works inside there because it is kept such a secret- nobody wants to place a diagram in their manuals which will show us how it operates .
I have a similar problem with my Rav- (see my posting)
My common sense tells me that the central diff must be vacuum applied and spring released. Otherwise it will engage automatically ( by the spring) at a high speed if a vacuum hose fails and that will be fun and games .
Personally I think that your central diff vacuum booster/chamber/activator diagphragm is punctured ( if all your vacuum hoses are fitted correctly).
Anyway - if you shoukld ever be so lucky to stumble accross a manual or description on the operation of these transmissions - please let me know at johnjnam@yahoo.com.
Good luck
John
leggyloo2
Nov 3 2009, 12:52 PM
[/quote]
Hi Leggyloo
Good luck
John
[/quote]
Hi John, I'm hoping to have some answers later today Im going to try & ring the number above that the kind Bothwell_buyer has given me to try & get some advise so if it works & i get to the bottom of the problem, i will let you know or if I manage to get any diagrams & ill email them on to you. Even if somebody understood how it works & could sketch it on a bit of paper then upload it would help. but ill certainly pass any info i get on to you, please could you also do the same. I do love my Rav4 but I have never come across so many wire, pipes, electrics etc etc on a car as this one has & all squashed into a very small area. the engine change took 4 days just to get it out, normally id have an engine in & out in a day. i have an awful feeling though that somethings been damaged during the engine change, especially the bracket above that i speak about. anyway, ill let you know any info if any comes to me...thanks Laura
Davrav
Nov 3 2009, 02:48 PM
QUOTE (leggyloo2 @ Nov 3 2009, 12:52 PM)
Are you spoken for?
leggyloo2
Nov 3 2009, 09:44 PM
yes but Ive been in my garage that much over the last week he mite av packed up + left me.!
leggyloo2
Nov 3 2009, 10:33 PM
Yippeee.!! The diff lock has disengaged. ill try+explain what the problem was. It was realy hard to get to as well, I must be double jointed.!! Cumin out of the diff is a 90 degree bar that locates threw a hole in a bar that cums out of the servo. When the diff locks + un-locks these move together one way or the other. But it wasnt doin this becos the 90 degree bar had cum out of the hole + instead was jammed up against the end of it. I ad to get the bottom bolts un-done from underneath the os wheel arch which hold the bottom of the servo. Then the top 2 bolts from the top of the engine between inlet manifold + bulk head which hold the top of the servo. I cud then pull the servo back slightly + then pulled the shaft out of servo as far as it wud go. I cud then hook the hole in the shaft back onto the 90 degree diff bar. I hope this helps sumone in the future shud they av the same problem. Thankyou to everyone for all the help + advise uve been great. Im goin to post a new thread now as ive cum across another problem this time its the engine.!
anchorman
Nov 4 2009, 05:32 PM
Well hats off to you for getting stuck in. Well done!
I've pm'd you on the engine issue.
johnjnam
Nov 5 2009, 05:02 AM
QUOTE (leggyloo2 @ Nov 4 2009, 12:33 AM)
Hi Leggyloo / Anchorman
Well done Leggyloo.
I have also solved MY "problem" and the emphasis is on the MY/ME not the Rav cause it was me that could not understand the operation - the Rav is fine . I found a diagram somewhere on the net but now cant locate the site again of the gearbox and have worked out the 4wd/awd. I will tray to attach it here
Thanks for your help
John
leggyloo2
Nov 5 2009, 06:29 AM
Thanks John, appreciate that. Ive dropped you an email as well, laura
three5
Nov 5 2009, 04:46 PM
QUOTE (leggyloo2 @ Nov 3 2009, 10:33 PM)
Congratulations Leggyloo - I've been watching this thread with baited breath. You get 11/10 for persistance
leggyloo2
Nov 5 2009, 07:16 PM
Thanks chris. When it fist happened I trawled the internet lookin for help + advise but cudnt find much about the diff. I joined toyota owners club + I cant believe how helpful everyones been. I Hope one day this topic will help sumone if they av the same fault. Thanks laura
anchorman
Nov 5 2009, 09:05 PM
QUOTE (johnjnam @ Nov 5 2009, 05:02 AM)
Well done Leggyloo.
John
Good info John - that is the manual we want to get hold of. If anyone knows where there is one for sale please let me know.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
