I am stuck here and need some info on how this Rav 4 Transmission works .Somehow it all does not make sense to me .
I have been searching the internet as well as the Toyota dealers around here high and low for info but was unable to find any . There is so much talk on limited slip diffs , traction control , Viscous drives – name it - but nothing is making sense here .
I don’t know why the info on the rav transmission seems to be kept as a state secret .
Even the workshop manuals don’t tell you exactly what is happening inside the transmission of these vehicles .
My Rav is a 1999 3 door version with a 5 speed transmission . Also has ABS . The vin number is SXA10-0033851 .
From what I can gather the manual transmission is a front wheel drive until the centre diff is locked , The it becomes a AWD with equal power to the front and rear wheels . The Automatic version is a permanent AWD which will allow more power to the rear wheels if and when needed due to slipping .
Allow me to tell you what I did :
First I checked if the diff lock works by jacking up the front of the vehicle , putting it into gear and “drive’ it . Only the front wheels rotate .
Then I engaged the diff lock , applied the hand brake and when I let the clutch come out carefully I can feel the vehicle stalling - so the diff lock works .
Then I jacked up the rear vehicle and rotated the rear wheels - they rotate into opposite directions- so it’s a normal diff and not a limited slip diff.
But if I jack one rear wheel only and try to rotate it - it locks up , it does not rotate the rear prop shaft , even if the diff lock is off .
Surely it should now be free to rotate ?? If the diff lock is off.
Why would it do that ? Is the centre diff of some limited slip type ? Has the ABS to do something with it ?
I would appreciate it if you could help me with this .
If possible could you also forward your answer to this directly to me to johnjnam@yahoo.com because I cant always get into this site from this end of the world .
Thanks again and wishing you a super day
John
