Help - Search - Members - Calendar
Full Version: 1987 Camry Fuel Pressure Problem
Toyota Owners Club - Toyota Forum > Toyota Forums > Toyota Performance
kjkircher
Would appreciate help on the following.
I have what I think is a typical problem on the 87 Camry 4 cyl engine.
New fuel pump installed AND it works if current is directly applied. I suspect that another component such as the cold cycle start delay, or a fuse/relay is the problem.
Could someone please tell me the actual locations of all related components on the engine?
Any other guesses as to what the problem is??
MyV6Flys
Have you checked all your fuses??
kjkircher
Thx for the reply.
I have checked the relays and fuses in the under the bonnet box. Same for the kick panel fusebox under the dash.
Are there other locations??
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
