sandgroper
October 15, 2004, 2:44 am
I dont have an V8 Amazon or electric windows,but from reading other posts on other forums the older models seem to suffer from a voltage drop in the mechanism inside the doors.
Usual reason is bad connections ,either in the door or sometimes on the battery cables.
The electric windows draw a lot of power and everything needs to be perfect.
Again its usually the drivers that goes 1st.
Another problem is the flocking or window guides wear out and allow the window to tilt diagonally a few degrees and put enormous strain on the winding mechanism as it pushes against the friction.This would usually only apply to well worn landcruisers like mine
Your rear wiper motor is at least working as its resetting itself as it should.
I would test the wiper switch on the column and have a look inside the rear door.
If your not good with testing equipment,like me,get someone who is good but outline the tests you want done.
There is a lot of wiring in those 100 series
