[quote name='atlis' post='515508' date='Mar 22 2006, 10:29 PM']
hi xt4 great pointer thanks
i know on the fitting instructions it has the antenna placed on top of the speedo clocks(inside the dash) is this where yours is placed?how can toyota justify £192 for this part?!!! i'll keep you posted on progress.thanks again
[/quote]
Hi Atlis
Yes I downloaded the Toyota fitting instructions, and fitted the antenna as they recommend. They show a strip of metal, so I found something suitable in my garage and stuck it in place using double sided tape, then placed the antenna magnetic base on top. My system also has the optional ETA, a super gadget that gives traffic info
The antenna for this is also very expensive £153
This has a special FARKA connector, which is used by BMW and MINIs a local car radio shop found me a suitable cable and I added a splitted box the existing radio lead and fed the signal to each unit. The whole system has worked wonderfully, and took us down through France to a hotel by just entering the phone number
On the way back ETA warned of slow traffic on M25
