ECU Pin Outs can be found here
http://www.hkseurope.com/ under instructions / ECU Pin Out.
ECU Type is T15 from HKS installation manual.
Type 1 SLD- there are 5 wires only 4 are used.
Connections are:
B 12v Ignition Supply
Red (double bullet connector) cut wire from ECU one red connector connects to ECU other connects to wiring harness side
E Earth (Ground)
Black (double bullet connector) cut wire from ECU one black connector connects to ECU other connects to wiring harness side
S Speed Sensor Cut this wire
Yellow connector connects to ECU
White connector connects to wiring harness side.
The dip switches SW1 and SW2 (1 2 3 4) are all in Position ST-1 all in the up position (off).
Remove the glove box completely- I found that you need to remove the plastic trim for the door kick plate on the passenger side as there is a couple of bolts holding the glovebox assembly on.
To get to the ECU (it's behind the centre console) you need to remove the Stereo surround fascia. All the stereo brackets (metal cage- screwed in). Remove the complete gear shroud assembly and armrest- 4 screws in all- removing gear knob to lift it away completely. The ECU is held in by 4 screws to a metal frame.
Move the ECU to a position that will allow access to the connectors at the rear and splice in the connecting wires as per Images above ( pinout/ECU diagrams).
Use the sticky pad to attach SLD to the rear of the ECU when wiring completed-cover the dip switches with the supplied label and connect all 3 plugs back into ECU. If you are confident the wiring is correct then turn on ignition and let the car idle for a while to see that it is not going to cut out (or catch fire!!!). If satisfied then attach ECU to plastic frame then begin the re-assembly procedure making sure that all bullet connectors are secure (cable ties come in handy here) and tidy the cables from the ECU when assembling so that they don't snag.. replace the gear surround/arm rest, then the glove box assembly. Reinstall any stereo equipment and the fascia surround.
Take the car to a private test track and watch the needle advance past 180kph and listen....ahhh no speed limiter engaging... Jobs a good 'un.....
