Help - Search - Members - Calendar
Full Version: Rav 4.3 - Possible Oil Leak
Toyota Owners Club - Toyota Forum > Toyota Forums > Rav 4 Club
bomber06
I parked the RAV off the drive this morning and where I usually park it there is an oily stain on the drive. I checked the oil levels in the car and they were fine. :o
While looking for the manual. I come across the service report from April 2007 (its first service performed by the cars previous owner). The Visual Safety Report highlights a possible oil leak with the comments "Oil leak Suspect Timing Chain over" and given a tick in the amber relevant box. There is no indication whether the problem was rectified. Although, on an additional service sheet the check for leaks is ticked rather than a crossed,which would indicate that no attention was needed.
Having only owned the car since November I am a little worried about the oil leak. Can any of you Tech Guys put my mind at ease and tell me if a leak from the Timing Chain Cover a common problem, whats involved to fix it and will it be covered under warranty. Or could there be any other reason for the leak, the car has only done 13K miles.
I am booking in the car for its 2 yearly service next month and would liked to armed with info to pass onto Mr T.
Any advice would be really appreciated.
Thanks in advance!
Chris :help:
anchorman
Well I hate to tell you this but there might be a sump leak issue. Somebody I know took their RAV for a service and they wanted to book it in for a sump leak. They say it is a 14 hour job but I've looked through the engine build instructions and can't see why - maybe there is more "digging" than it would seem.
In the event there was no leak but something made them suspect it.
I am not aware of any other issues. You should take it in and let them sort it under warranty.
Please keep us informed for future reference.
Regards
shcm
I didn't want to say anything, until AM had posted, 'cause I suspected he would :D.
Now, I wonder who that could have been - that had the so called sump leak? :rolleyes:
What I think it was, was a bit of shoddy amateur mechanics on my part. :nono:. I change the oil every 5k and don't think I ran the engine long enough to check for leaks after the last filter change. There appears to have been a slight weep from the filter housing drain plug, which was evident on the plastic "tray" below the engine. Typical - I've done loads of oil changes and never had that. It's fine now - no leaks evident. The tray below the engine was taken off (not at the dealer!) to have a look around the sump, but it looked OK.
As AM says though, maybe worth taking it for the dealer to have a look. I didn't want them stripping mine apart, unless I too was sure it was a sump leak.
Just wondering if there is an issue, then as the 2AD-FHV (T180) and 2AD-FTV (T140) engines are used across the Toyota range, then it might show up in other bits of the forum. Although, I think they are made in more than one plant and it's not impossible for it to be an issue with just one assembly plant - if it's an issue at all that is.
Cheers :thumbsup:
duncerduncs
[quote name='anchorman' post='725361' date='Feb 24 2008, 01:17 AM']Well I hate to tell you this but there might be a sump leak issue. Somebody I know took their RAV for a service and they wanted to book it in for a sump leak. They say it is a 14 hour job but I've looked through the engine build instructions and can't see why - maybe there is more "digging" than it would seem.[/quote]
Sorry to drag up this old thread, but my car has sprung an oil leak! :(
There is nothing visible (i.e oil on the drive), but during my 20k service a "small oil leak from the sump" was found and my car has been booked in for 14 hours from the 7th May!
When I enquired whether the leak was from the oil sump or the gearbox oil, the technician advised me that the leak was definitely from the sump but he knew all about the problems with the 6 speed gearbox on D-4D engines...
anchorman
[quote name='duncerduncs' post='745235' date='Apr 21 2008, 01:27 PM'][quote name='anchorman' post='725361' date='Feb 24 2008, 01:17 AM']Well I hate to tell you this but there might be a sump leak issue. Somebody I know took their RAV for a service and they wanted to book it in for a sump leak. They say it is a 14 hour job but I've looked through the engine build instructions and can't see why - maybe there is more "digging" than it would seem.[/quote]
[/quote]
I don't know if you have any ramps but I looked at one with a reported oil leak and there was nothing there - certainly nothing I would take the sump off for. Might be worth popping that cover off (10 minutes) and having a quick butchers.
duncerduncs
[quote name='anchorman' post='745320' date='Apr 21 2008, 06:07 PM']I don't know if you have any ramps but I looked at one with a reported oil leak and there was nothing there - certainly nothing I would take the sump off for. Might be worth popping that cover off (10 minutes) and having a quick butchers.[/quote]
Thanks for the advise, but our drive is on a slope and I don't fancy getting under the car on the main road!
There's been no obvious oil leak from the car, so it makes me wonder just how bad it could be... :unsure:
duncerduncs
After sitting on the drive overnight the car had leaked oil onto the drive, so it's now back at the dealer!
I'm left with an Auris to drive :( (nice car, but not the same as my Rav!)
Parts-King
[quote name='duncerduncs' post='745820' date='Apr 23 2008, 12:11 PM']After sitting on the drive overnight the car had leaked oil onto the drive, so it's now back at the dealer!
I'm left with an Auris to drive :( (nice car, but not the same as my Rav!)[/quote]
AURIS!!! I must have a word with them and see if they can get you into the obigatory YARIS :lol: :lol: :lol:
Kingo :thumbsup:
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
