Help - Search - Members - Calendar
Full Version: Lc V8 Seat Belt Alarm
Toyota Owners Club - Toyota Forum > Toyota Forums > Toyota Landcruiser Club
DM51
1st post - just registered today.
I have a new Diesel V8 Land Cruiser - a big improvement on its predecessor, an Amazon, which I had for 4 yrs.
However the new V8 has an extremely annoying alarm which bleeps loudly after ~400 yds if you haven't fastened the seat belt. This is OK for on-road use, when I always fasten the belt anyway, but I will be using the car off-road quite a lot when a seat belt is an actual nuisance. I assume the alarm is one of those stupid nannyish items which you aren't supposed to be able to turn off, but I'm wondering if there is a good hack anyone knows which could fix it.
I found this old post in the Avensis section here:
[quote name='Zz24hours' post='368444' date='Jun 10 2005, 02:46 PM']Just got told how to disable the alarm for the seat-belts. Ofcourse you should allways wear the seatbelt when driving, but on occasions it seems terribly annoying
[quote]This is how you do it - sorry for my bad translation
Turn power on and set counter to "ODO"
Turn power off
Turn power on, within 5 seconds, press and hold the trip-reset button
After 10 seconds, fasten the seatbelt
Release the trip-reset button
.. the display should now change to "B-off", turn power off and release the seatbelt.
The alarm is now disabled. To enable it again, same sequence but push the trip button once again with the seatbelt fastened. The display shows B-on. (thanks for the update, Nick)[/quote][/quote]
However this is a 3-year-old post and relates to an entirely different model.
Can anyone help?
Parts-King
I'm not sure how much a nuisance it can be to NOT wear your seatbely offroad, what conditions would make it safe to leave your seatbelt undone? The bleeping is put in place to make you wear the belt and to gain the vehicles NCAP safety rating. Why not just fasten the seat belt, prefereably with you in it OR fasten the belt first and then get in. I think its as easy to wear the belt rather than disable an important safety feature
Kingo :thumbsup:
DM51
[quote name='Parts-King' post='765403' date='Jun 21 2008, 04:58 PM']I'm not sure how much a nuisance it can be to NOT wear your seatbely offroad, what conditions would make it safe to leave your seatbelt undone? The bleeping is put in place to make you wear the belt and to gain the vehicles NCAP safety rating. Why not just fasten the seat belt, prefereably with you in it OR fasten the belt first and then get in. I think its as easy to wear the belt rather than disable an important safety feature[/quote]Believe me, it can be a nuisance, for example when you have to stop every few hundred yds and get out to open a gate, load things etc.
I am very well aware of all the safety regulations, and I do not need my car to add its own voice to those of the innumerable bossy, safety-obsessed twerps to be found everywhere nowadays and "make" me wear my seat belt when I neither need nor want to wear it. As I said above, I always wear it on the public roads. I just don't want to have to wear it (or sit on it) when I'm off-road. The bleeping is not an important safety feature. It is an unnecessary and annoying one.
DM51
I have found the perfect solution to this problem. The alarm is now silenced. An easy fix.
DaveMan
[quote name='DM51' post='768576' date='Jun 30 2008, 10:42 PM']I have found the perfect solution to this problem. The alarm is now silenced. An easy fix.[/quote]
Hello,
Please inlighten us. I have a V8 LC
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
