Help - Search - Members - Calendar
Full Version: 1993 Toyota Trueno 4afe-overheating!
Toyota Owners Club - Toyota Forum > Toyota Forums > Toyota Performance
2rueno
hae all i really need help!!! i have a 1993 toyota trueno sprinter/levin with a 4-afe in it. Its done 237 ks and is a gr8 car...apart from the fact it overheats!!! sad.gif i had the head taken off and planed, new headgasket, new headbolts etc put all back 2geather couple of days ago n it still isnt right mad.gif mad.gif its so bad u can here the water boiling in the head!!! so checked the thermostat and tried it with no thermostat and yup u guessed it it over heated!!! im about to check the water pump but i have noticed that there is white foam when radiator cap is off and engine running i have tried topping it up but the water level goes back down unsure.gif there is a sticker saying the radiator has been serviced at sometime in its life... Please what is the problem with my car any help would be much appreciated
bigshark
after the car has been running a while, do you get any hot air when you put the heater blower on?
it could well be the water pump, or an air lock!
however it does sound like the symptons of a headgasket failure!
2rueno
QUOTE(bigshark @ Jul 19 2008, 04:02 PM) *
yup plenty of hot air comes out.The headgasket has just been replaced couple daes ago along with the head being skim planed. checkde thermostat drove it without it and it still overeaheated. Theres no water in the oil etc. as for the water pump took it off 2dae and clean as a whistle. can be driven for bowt 30 ks if im lucky n then thats it gets 2 hot n i dont wana blow it. fan kicks in when it should etc. when i start it cold there is alot of condenstation and white mist coming out. and notice that when engine runs and u have radiator there air bubbles,and white scum/foam coming up if i fill it up the water level goes down.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
