[quote name='Hoovie' post='791016' date='Aug 27 2008, 10:26 AM']Still got that 'orrible VW Avatar, Llith
Re MOTs, now they are computerised, you don't even need the Reg Doc - the system automatically puts in the right date
(I took mine along for that reason and they said they didn't need it as it was automated and they were right
)[/quote]
Hoovie , got the info from the DVLA website :
''If the vehicle is tested within the calendar month prior to when the MOT is due, the test certificate will run from the date of the test to one year after the expiry date of the current certificate. For example, if the current certificate was due to expire on 1 April 2007, and the vehicle was presented on or after 2 March 2007, the certificate would run from the test date until 1 April 2008.
The same rule would also apply when the vehicle is taken in within a calendar month of its first MOT. In this case, the vehicle owner would need to present their registration document.''
So my advice to Nick would be to take the reg doc for the first MOT,just in case.
Avatar stays until I make a decision on my next car
