So my '97 Rav went to Toyota because of an immobiliser problem. They said the key simply needed reprogramming (not the remote fob, the key itself) and my cambelt and tensioner needed replacing as well! (Unrelated to immobiliser snag)
So, I did the cambelt with a little bit of help from you guys, but my key still won't start the engine, the grey 'master key' works, luckily! i'm wondering if they recoded my key at all.
Is there a way to reprogram the key or just test it without paying Toyota prices? Do they have a battery inside or just a chip kind of affair?
I'll give the original symptoms for the benefit of anyone experiencing similar problems:
Car locks/unlocks remotely as normal with remote fob.
Key operates ignition as normal.
Engine cranks but doesn't fire .
Spark is present.
Fuel is pumnping to manifold.
There are some electronic fuelly things on the back of each cylinder that aren't letting the fuel in.
(Help me out here with the technical details?!)
RAC man scratches head, phones a friend, then tows it away to Toyota!
We didn't try the grey 'master' key at the time or the penny may have dropped because it starts fine with this which proves it's not an engine problem.
So top tip: IF YOUR ENGINE CRANKS BUT DOESN'T FIRE, TRY WITH THE MASTER KEY!
I didn't know these were anything more than a normal key, there's nothing obvious to suggest otherwise so I suspect this has caught out many people of the years.
Any help appreciated...
Cheers
Sly
