Help - Search - Members - Calendar
Full Version: Reversing Camera - Using It!
Toyota Owners Club - Toyota Forum > Toyota Forums > Rav 4
Hoovie
I fitted this reversing camera and it is all up and running - stick the motor in Reverse and see the image behind me and all that :thumbsup:
But .... I am finding it hard to judge the distance. If I look at the screen it seems I have plenty of room, but when I look behind me out the rear window, I am pretty close to whatever I am reversing to :blink:
I guess I have no point of reference with the camera image?, plus need to get used to it (never had a reverse-cam before)?
Any tips from you guys with the cameras?
Phoenix999
I used to have a Primera with a camera and found it to be extremely accurate :yes:
Try reversing up to a small plant (of course it won't hurt your car if you touch it) if it looks very close then stop and get out and physically measure it for yourself. I used to be able to reverse up to things and judge a gap of about 3 inches, they really can be that good :)
I have the front and rear parking sensors and they are very good but cannot judge a gap much less than 30cms so I sort of miss the camera :huh:
dave.m
Hi mate, thats the problem I had, which is why I switched it to 15 degrees from vertical. You cant see
everything behind, but you can see the edge of the bumper. :thumbsup:
Hoovie
Cheers Guys :thumbsup:
Think I will do a little "soft target" practicing first to see if using it 'clicks' in place, but suspect will end up having to angle it (means a bit of a stripdown :( )
chatman
[quote name='Hoovie' post='816841' date='Oct 30 2008, 08:24 AM']Cheers Guys :thumbsup:
Think I will do a little "soft target" practicing first to see if using it 'clicks' in place, but suspect will end up having to angle it (means a bit of a stripdown :( )[/quote]
Fit your tow bar and use the touch crunch approach...when you get to hear no crunch any more..you know you've cracked it..... :lol: :lol: :lol:
Hoovie
anyone rememeber "The Dambusters" and how they cracked the low level night flying over the dams? using two spotlights that lined up at 60 feet?
That could work well :) Fit two cameras - one each side - angled in, and you get a double image, like bino's not set right - and as you reverse, the image starts to 'come into focus' and when sharp, you're 6" or whatever from the obstacle.
Pete046
[quote name='Hoovie' post='816929' date='Oct 30 2008, 02:11 PM']anyone rememeber "The Dambusters" and how they cracked the low level night flying over the dams? using two spotlights that lined up at 60 feet?
That could work well :) Fit two cameras - one each side - angled in, and you get a double image, like bino's not set right - and as you reverse, the image starts to 'come into focus' and when sharp, you're 6" or whatever from the obstacle.[/quote]
Or you could gaffer tape a torch to each side of the bumper, angled in, and when the beams meet you know you are there. Eassily adjustable for different distances.
Might be a bit of a pain getting out each time you reverse to switch them on though :D
chatman
[quote name='Pete046' post='816987' date='Oct 30 2008, 04:09 PM']Or you could gaffer tape a torch to each side of the bumper, angled in, and when the beams meet you know you are there. Eassily adjustable for different distances.
Might be a bit of a pain getting out each time you reverse to switch them on though :D[/quote]
NA... that's what his wife is for....even better now the cold days are here..... :yes: :yes: :yes: :yes: :yes:
dave.m
[quote name='Pete046' post='816987' date='Oct 30 2008, 04:09 PM'][quote name='Hoovie' post='816929' date='Oct 30 2008, 02:11 PM']anyone rememeber "The Dambusters" and how they cracked the low level night flying over the dams? using two spotlights that lined up at 60 feet?
[/quote]
Pete, you are going to fit in this Rav forum a treat :thumbsup: :thumbsup:
Hoovie
Think we are starting to lose touch with reality here boys. :rolleyes:
on second thoughts, scratch the words "Starting to" :lol: :lol:
inset a couple of LEDs at an angle, powered by the reversing light wire ..... Hmmm ...... :ph34r:
Dutchrav
Nice idea. With the light from a bright LED you can see the reflection of it and use it for reference.
But it will not work at the day...
Or...mount a laserpointer!
Hoovie
or ..... a Motorised Steel Rule, mounted in a special compartment under the camera.
[img]http://www.screwfix.com/sfd/i/cat/81/p2464781_l.jpg[/img]
When reverse is selected, the rule pushs out a couple of foot, then as you reverse the car, the rule is pushed back in by the obstacle (other car, wall, granny, etc) and you can see the distance from camera to object to the millimeter by reading the markings on the ruler in the screen display :thumbsup:
I'm off to the Dragons Den with this one :yes:
shcm
[quote name='Hoovie' post='817030' date='Oct 30 2008, 05:37 PM']I'm off to the Dragons Den with this one :yes:[/quote]
Sorry, I'm out.
shcm
Can I expand on Chatman's idea?
Stop messing about, go for the heavy engineering approach and just fit these handy things. You know it makes sense. :yes:
(Sorry for defacing your excellent RAV by the way).
[img]http://i208.photobucket.com/albums/bb315/shcmpb/buffers.jpg[/img]
Dutchrav
[quote name='chatman' post='816992' date='Oct 30 2008, 05:26 PM'][quote name='Pete046' post='816987' date='Oct 30 2008, 04:09 PM']Or you could gaffer tape a torch to each side of the bumper, angled in, and when the beams meet you know you are there. Eassily adjustable for different distances.
[/quote]
Just put the wife with gaffer tape on the back. If she really screams you´re there. :lol:
dave.m
[quote name='shcm' post='817078' date='Oct 30 2008, 06:51 PM']Can I expand on Chatman's idea?
[img]http://i208.photobucket.com/albums/bb315/shcmpb/buffers.jpg[/img][/quote]
:lol2: :lol2: :lol2: :lol2: :lol2: PMSL whats the betting Anchorman and Duncs will be wanting one of those.
chatman
[quote name='dave.m' post='817132' date='Oct 30 2008, 09:01 PM'][quote name='shcm' post='817078' date='Oct 30 2008, 06:51 PM']Can I expand on Chatman's idea?
[/quote]
It had to involve trains!!! :rolleyes: :rolleyes: :rolleyes: :blowup:
Dam good pimp though Hoovie.....don't you think...You could get a part time job Shunting shopping trolleys in the local supermarket carpark :lol: :lol: :lol: :lol: :lol: :lol:
Hoovie
I wondered that was from, actually :)
I was thinking maybe those round things (buffers?) could be cutting disks and rotated around ready to make more room in parking spaces :yes)
chatman
Hoovie....I have some mates who still drive these...You could have the first RAV4 APC.....Now there's a PIMP for ya...............
[img]http://www.armedforces.co.uk/army/listings/armywarriorb.jpg[/img]
But maybe this is taking the parking thing a step too far....They never have problems of people parking too close or just clipping the wall..........
:P :P :P :P :P :P :P :P :P :P :P
Hoovie
Is that a Zoom Lens on top of the big moon roof? :P
anchorman
At last a decent bull bar. Can I get one for the front!!!
local hero
[quote name='dave.m' post='817132' date='Oct 30 2008, 10:01 PM'][quote name='shcm' post='817078' date='Oct 30 2008, 06:51 PM']Can I expand on Chatman's idea?
[/quote]Hoovie if you fit those back + front and remove all four shockers You could have the worlds first RAV4-PENDOLINO :toot:
Hoovie
[quote name='local hero' post='817446' date='Oct 31 2008, 05:37 PM']Hoovie if you fit those back + front and remove all four shockers You could have the worlds first RAV4-PENDOLINO :toot:[/quote]
Oo Oo ... More Pimps :thumbsup: :thumbsup:
local hero
Hoovie, local heroine has been very concerned about you she has heard terrible weather repots for the S.W. floods + snow etc are you OK?
Hoovie
We were lucky :thumbsup: the town that got the worst of it was just 8 miles or so North.
We had the thunder, lightenining and power kept going off but apart from a lot of rain, no problems :)
Thanks for the concern :), much appreciated.
shcm
[quote name='local hero' post='817446' date='Oct 31 2008, 05:37 PM']remove all four shockers You could have the worlds first RAV4-PENDOLINO :toot:[/quote]
Could add an active roll control pimp, so he could lean into corners :unsure:
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
