Well just to add. Took delivery of a 2.0 D4D TR Saloon a week ago and so far done 1200miles
[b]Like -[/b]
Quiet and relaxed on the motorway
Good ride
Holds the road well
Good brakes
Feels solidly made so far no squeeks or rattles
Like the looks
Sat Nav works well and easy to use once you've figured it out
Clever folding sliding centre armrest and big storage area
Safety features
[b]Dislike -[/b]
Seats are [i]ok[/i] for short journys but uncomfortable and give me backache on anything much over 40mins
No Lateral support
Seatback doesnt have fine adjustment, the spacing betwean the notches is too great.
Sometimes when you just want to wind the seatback back a notch it jumps back several
No tilt adjustment for the seat
And yet it has power Lumbar support!?
Built in Bluetooth carkit keeps disconnecting from the phone
[b]**edit** [/b]It works perfectly with my old Ericsson, just my Nokia that has a problem
When it does work and you get a call it mutes the Sat-Nav, so to avoid missing a turn you have to pull over and stop to take the call, if you have to pull over and stop to take the call... whats the point of a carkit?
[b]**edit**[/b] I have discovered that if you press the Map/Voice button while in a call you get the sat nav screen back. Doesnt bring back the voice guidence but it does give you visual guidence so thats all fine now.
Sat Nav can only store 106 POI's... slightly annoying when my previous sat nav device (a phone) has got 120 POI's
I've been driving carefully and am only getting around 513 miles from the 60litre tank, compared to 600miles from my old car with 110,000 on the clock and the same size tank and engine
[b]**edit** [/b]I think the fuel guage an range estimation are a bit pessimistic, its a 60litre (13.1gal) tank, I'm doing 52mpg which if you do the math gives a range of 681miles. Further backed up at the pumps I apparently had 8miles range yesterday but it still only took 48litres to fill up so despite it saying I only had 8miles left there was a further 12litres (2.6gal) in the tank so I actually had 135miles left not 8
Climate control only seems to blow out of the front vents, everytime I select a different vent it switchs off, then reverts to the front vents when I switch it on again. maybe just because I havent figured it out yet?
[b]Faults [/b]
ABS warning light came on and check VSC message displayed, switched engine off and restarted and it was fine, hasnt done it since.
Drivers door difficult to open sometimes from the inside, the handle doesnt do anything first pull and then the second time you pull it it's stiff, theres a crunching sound and it opens.
[b]General Comments[/b]
Saloon not that practical and Estate too expensive and too big, and uneccesary. I understand only 15% of Avensis sales were a hatch so it's been deleted but I'd prefer one and so would everybody else I've spoken to.
Handling's ok for a big car, perfectly acceptable but not as good as some others. not much feedback from the wheel.
Just speaking as I find.
Dont get me wrong I do like it though
just wish at least some of the things I dislike could be sorted.
