Help - Search - Members - Calendar
Full Version: Air Conditioning Not Working
Toyota Owners Club - Toyota Forum > Toyota Forums > Toyota Landcruiser
dp639
The A/C is not working on my 2003 Landcruiser. The light has been blinking for a while now and now that the 'warm' weather is coming it is noticeable the air is not cool anymore. After some research it seems the relay could be playing up, relay is 90987-02022.
In the relay box there are 4 or 5 of these, anyone know which relay is used for the A/C. Unfortunately there isn't a relay diagram on the vehicle anywhere. If I found out which is which I could swap them around to see if it is indeed the relay that is the problem.
Thanks in advance.
s m smith
QUOTE (dp639 @ Mar 23 2009, 09:20 AM) *
Thanks in advance.
the system might need topping up with refrigerant,
Elenar
Thanks in advance.
Hmm, I wonder if it is the same problem I have? See my post about losing my cool. A relay you say? How much is this, is it something I can do?
dp639
QUOTE (Elenar @ Mar 23 2009, 02:13 PM) *
Thanks in advance.
Very simple to do - if that is the problem, see these links
http://www.toyota-4runner.org/showthread.php?threadid=18321
http://www.toyota-4runner.org/showthread.p...=flashing+a%2Fc
dp639
QUOTE (s m smith @ Mar 23 2009, 10:01 AM) *
Thanks in advance.
Do you just mean coolant?, if so then that is not the problem as I've plenty of that.
s m smith
QUOTE (dp639 @ Mar 23 2009, 02:28 PM) *
Thanks in advance.
no the system uses refrigerant, like the stuff used in fridges and freezers, R-134a its used as a heat transfer agent in the air con system, this could be low and the system needs regassing
dp639
QUOTE (s m smith @ Mar 23 2009, 02:43 PM) *
Thanks in advance.
How do you check for this, or is it more of a dealer job? I'll try changing around the relays first and see if that cures it, if not then a trip to dealer unfortunately.
Thanks alot.
s m smith
QUOTE (dp639 @ Mar 23 2009, 03:02 PM) *
Thanks in advance.
Thanks alot.
dealer can do it or any air con specialist, but try the relay first it could be that, had the same problem on an old Supra, they sorted it by regassing the air con system Good luck lets us know how you get on
Lady Cruiser
I had the same problem last year.
I had it re-gassed and its now as good as new!!!
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
