rhino373
May 11 2009, 07:31 PM
hi people,
i'm new to this forum & have my colorado for a year my sister had it for 4 years before me with no problems.
but tonight whilst driving to over a roundabout all was fine then it lost power,then stopped immediatley! opened bonnet checked cam belt hadnt snapped everything looks good,no oil loss,water ok....... tried to start it & over it cranked tried to start smoked quite a bit then had a little diesel knock!!! now nothing!
got towed to my workshop & am pondering.....?
???? does anyone think lift pump as when pumping hand pump doesnt feel like its pumping....
pulled outlet hose off & nothing?
anyone got any ideas.....before i give it some open heart surgery....
many thank's neil
Andy
May 12 2009, 07:19 AM
Have you changed the fuel filter, also check the fuel lines back to the tank, maybe you have a hole in the line or the small filter inside the tank is clogged.
rhino373
May 15 2009, 07:09 AM
hi andy,
tank been out cleaned gauze filter in tank on pick up pipe....pressure tested.
gone as far as running a direct pipe from tank to pump & electric feul pump in line.... no disruptions in the way.
plenty of pressure to pump...but nothing out of pump! tested spill valve to make sure it powered up...
still nothing....may have to dip into the denso pump & have a look.
Andy
May 16 2009, 07:31 AM
You could try a new lift pump on to of the filter, also try some clear fuel pipe between the lift pump down to the injector pump, then you will see if your getting air in the system.
rhino373
May 16 2009, 04:45 PM
hi andy ,
found the problem.....
pump must have locked up momentarilary? took out pressure swith & found alloy filings.....
so took pump off & found that the pump drive to cam belt pulley has snapped through the woodruff key...
so now i'm happy. found another pump been told toyota want 2k for a new 1
will post up some pictures monday as i didnt strip pump this afternoon!
if any 1 has a denso pump 096500-01315/toyota number 22100-67070 leave me a message it is the electrical pump
many thanks neil
Teknys
May 19 2009, 10:42 AM
From experience this is normally caused by poor fuel, i.e petrol instead of diesel and home made veggy fuel can cause accelerated wear.
rhino373
May 21 2009, 04:45 PM
QUOTE (Teknys @ May 19 2009, 11:42 AM)
not quite sure what went wrong teknys....yet until i get time to pull it apart? hasnt had any dodgey fuel as i only fuel up at shell garage at broadbridge heath.....and my sister did before hand....
hasnt had petrol in it as i'm the only driver.....
only thing i can think of is that the fuel tanker at some point had had a mixed load of petrol/diesel or diesel/kero? if they havent delivered full amount & have however many litres left in tank & fill up with diesel then you get a mixture! similar to what you buy from tesco the tanker flush
rhino373
May 25 2009, 09:12 PM
Click to view attachmenthere's the damage to the injector pump
Andy
May 25 2009, 09:51 PM
I cant see how this would happen, unless someone has beaten the sh*t out of it to get the pulley of before hand.
If you still need to get a pump you could try Dewsbury salvage, they always seem to have a couple in stock.
rhino373
May 26 2009, 08:58 PM
i got 1 from japman in kent! fitted last tuesday all seems fine now got russell birch a toyota man through & through ( who has just left toll house toyota and started up on his own) toyotec 07833 223205 to come down & do electrical tests as it just stopped & did seem a bit like a immobiliser or ecd shut down... russell did all the tests & completed the job very good knowledge & a superb guy
p.s i made russell a puller to push broken bit off of pulley beats buying a toyota (proper tool) lol
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
