Sluggish Landcruiser
gordon b reid
Hi
I have a 2001 toyota landcruiser 3lt turbo diesel with the D4D engine when working it hard not a problem but when you have to lift your foot or take off it has no power. Think the problem maybe with the pressure relief valve but can't see it was wondering if any of you guys would no where it is or would you know if it is on the pump itself ?
Also has anyone anyinfo on the common rail engine as this would proabably be of a great help as this is the same engine.
Gordon
Hi
Gordon
hi Gordon
- EGR vallve -- to be examinated and cleaned;
- all injectors -- to be pressure tested with jet spray shape etc;
Check and revert
Cheers/Igor
Hi
Gordon
hi Gordon
Check and revert
Cheers/Igor
Or blank off the EGR valve altogether ?
This just cured my Kia Sedona completely. Took about half an hour and cost tuppence. It went from running rough and smoking badly, to running like a dream.
