Car Jumpin Out Of Fifth
rob virgo
car has just had a new dual mass fly wheel and clutch done and box has been a little noisy for the 4 weeks since the job.car has now started to jump out of gear.
toyota mech did the job off the books but has now gone to aus for a year.
any ideas
rob
Just get yourself a new gear box. My avensis 1998 has similar issue, it turned out that was the problem!
Good luck
with the older fords ive worked on the linkage had to be fitted perfectly or it would select certain gears or would pop out of gears,is the avensis using the same linkage system.
what could have caused this during gearbox work,not happy if its a new box.was fine before
wheni got it back it was leaking oil badly and it got sent back to him.he changed the body gasket and it sorted the problem although it was noisy after.presume it was low .
has only started to jump out of gear in the last few days.
rob v
Maybe he has tried to use the old dirty transmition fluid.
I would recommend taking it else where and remove all old oil and refill correctly if with correct type.
will drop out the old oil tommorow and replace with proper oil.is it a specific oil type.
rob v
Drive it... warm it up nice and hot
10 ish miles of driving ..
Drain it.. leave it draning for a while.. (let it dip)
Then refill with a pump
best of luck let me know
cmia ,
havnt seen the box setup yet.drained from bottom i presume and no vacuum needed but why a pump to fill.dont have one.any other way.
is it because its in a tight location.
any photos
zaga
any ideas
rob
Hi everyone!
Before i bought my Avensis 2.2 D4D i was told to avoid any high mileage 5 speed d4d's as jumping out of 5th gear was a common problem (along with other issues) ..... so i got the later 2007 6 speed model.
Can anyone confirm this was the correct advice.
Regards .... Pete.
