Avensis T3-s
kriss aixill
Does anyone know whats parts can be added to a 2004 T3-s from any of the higher trim models?
Hi
The mosy effective upgrades are the leather seats and front centre console from the T-spirit.
All you need is to feed some power from the fuse box, so the powered seats will function - the other connections for the side airbags and seatbelt pre-tensioners are a direct swap, but remember to disconnect the Battery, before disconnecting and re-connecting the airbag leads!
I have just put the details on another topic this evening (need some comfort).
You can also swap the standard plastic interior sill protectors (with the Avensis name on them), for the ones with the metal inserts. I have just ordered some of these for myself.
Hope this helps.
