Yaris Oil Sump Pan Change - Help
grayfray
Hello, my son bought a 1.0 litre Yaris V reg year 2000
When we got it home we noticed that there was a small rust hole in the sump pan ( temp fixed it with araldite plumbers putty - great stuff). We have bought a replacement and can anyone tell me....
How difficult is it to change the pan
Is there any gasket or is it metal to metal and you just use silicone of sorts?
and can anyone tell me what the torque settings are for the bolts?
Thanks in advance
not too hard matey just lots of 10mm nuts no gasket just sealer.
but i will warn you it is hard to get it off(just coz of the sealer thats been used)
Thanks ormi
do you know what torque settings the bolts are?
Wring it off and go back half a turn! :D
I looked it up on my haynes manual and all i can find is the torque for the bolts on the oil resevoir and pump. It is 9Nm. Sounds about right but i'll have another look.
