Radio Fault
freescompany
The combined radio/sat nav unit on my 2002 Avensis is playing up. The radio stopped working but the sat nav still works. After removing the fuse to check if it had blown (It hadn't) the radio worked for a short while when the fuse was put back in. Removing and replacing the fuse gets the radio working for short periods. I fitted a unit from a scrapper and the problem still persists. Has anyone else had the same problem?
Thanks,
freescompany
Thanks,
freescompany
As you said that the radio worked for a short period, to me it sounds that the radio is infact ok. Maybe it is a connector plug problem. Is there one or more of the wires in the connector plug come loose ?. :lol:
