Disable Alarm Siren - Help !
nattyboy
Hi folks
We've lost the keys to our 4.2 and only have the grey service key. We need to use the car - does anyone know how to disable the siren/hazards ? Can you do it on a fuse ?
Im sure the keys will turn up as they are in the house but just need a quick fix !!
Cheers
Nat
If you have the grey key then inserting that into the ignition should silence the alarm sirens (this works on other Toyota's)... the idea being that it still has the transponder chip in it so the car knows it's not being stolen.
Tried that - unfortunatley it still keeps going :>(
Hi folks
Cheers
Nat
cut the wire...... you'll know you've cut the right one when the siren goes off. Course, nothing else will work but at least the noise has gone. :blink: :blink:
Next step - sort out the house.
