Xenon Headlamps
macsanmartin
Hi! I am from Argentina and have an intermittent problem with the xenon headlamps of my Avensis (short lights only). Suddenly, one of them turns itself off and remains off until y switch off/on. Then it turns on again, but after a variable time the problem repeats. Toyota servicemen have not been able to identify the problem. I don´t want to replace the lamps without knowing if the cause are the lamps or the ballast or something else. They are very expensive, besides.
Thanks in advance for any help.
Miguel
Switch the bulbs (right to left, and left to right)to make sure the bulbs are alright.
If the problem goes to the opposite side, the bulb is faulty.
Hi! I am from Argentina and have an intermittent problem with the Xenon headlamps of my Avensis (short lights only). Suddenly, one of them turns itself off and remains off until y switch off/on. Then it turns on again, but after a variable time the problem repeats. Toyota servicemen have not been able to identify the problem. I don´t want to replace the lamps without knowing if the cause are the lamps or the ballast or something else. They are very expensive, besides.
Miguel
hi there got the same problem on a new model rav4 and its was the bulb. the problem was when u switch it on everything is okay but after it went really yellow like 3000k bulb then it goes off.
