Gt-Four 205 Gear Change
GT4 James
Hi again all, just wondering if anyone can help me with this, have had a stage 1 cerrametallic clutch fitted for about 1 year now, ever since this was fitted i have been finding changing gear extremely difficult, was assured by guy who fitted to allow it time to "bed" in and is no better, cut a long story short hes not interested now and I just wanna resolve it. The only gear I have trouble with is 2nd into 3rd, if im under load is shockingly hard to get to change, leisurely driving conditions not too bad, any ideas would be appreciated, was thinking gearbox mounts myself but like i say has only ever done since new clutch fitted.
Thanks guys!
most likely the clutch pedal needs adjusting.
its a bit of a pain to get at, but if you go under the dash on the drivers side and look up at the clutch pedal, you will see a lock nut and adjusting bar (its on the clevis joint where the clutch master cylinder meets the pedal) undo the adjusting bar a few turns,so it becomes longer, and test, if its still hard try doing it a little more.that or take it back to the garage and get them to do it for you :thumbsup:
