Timing Belt Warning Light On
tabiri
Hi I just changed the timing belt of my 2007 toyota hilux and want to know how to reset the timing light on the dashboard. this has no screws at the back so i don't know how to do it. any answer will be greatly appreciated
  • 5 years later...
  • 4 months later...
To reset your Toyota Hilux timing belt warning light, simply.
  • Turn your ignition on.
  • Ensure your Odometer/Trip meter is showing odometer information.
  • Turn your ignition switch off.
  • Press and hold your Odometer/Trip display button whilst turning your ignition back on.
  • Hold the button down for 5 seconds and then release the button.
  • Within 5 seconds, press and release the button.
  • Your display should show the reset value
  • Press and hold the Odometer/trip button for 5 seconds then release the button.
  • Ensure the Odometer reading is displayed and the warning light should have gone out
I hope this helps you
