Vsc/tcs/engine Warning Lights - Smell Of Burned Gummy/plastic
sp00ky
Hi all,
I have Avensis 2.0 D4D 2007 126hp 90k km, today when I came to job from lunch I was smell burned plastic/gummy around the car. I was thought maybe is something in the air and I was go to work. Later when I was finish with the job and after starting engine warning lights for VSC, TCS and engine symbol is stayed ON, I was start to drive to home and notice that nothing of brake assistance (tcs, vsc) does not work, engine performance was OK.
When I park car home (after 10km), I was feel same smell of burned plastic/gummy.
Tomorrow I will try to read codes with my old ELM327 and see if I can find something, also I have previously scheduled regular service to Friday (regular service @90.000km) and that is the only luck i have :(
I'm owner of the car for last 6 months, now when i'm thinking , i think that i was feel that burned smell before (sometimes, not always). I was mentioned that to Mr.T when i was booking regular service.
I see other posts and seems this is very common error (except smell) and can be related to DPF, EGR, catalytic c.,fuel and so on...
What can I expect in my case ????
P.S.sry for my english, is not my natural language
post-96050-0-82566300-1294274726_thumb.j
hi again,
UPDATE:
I was connected my old ELM327 1.3a interface to car and working great :)
When I started reading DTC errors warning lights is still ON, then i was started car and put car working on idle warning lights is still ON. I was turn off engine after 2-3 minutes working on idle, take out/take in key and set ignition to position ON (no started engine) and now warning lights are off after self-test (everything seems normal) !!!
I'm not clear error code, it's still there. I hope that Mr.T. will explain what could be happen tomorrow at service
P0090 $10-Engine Fuel Pressure Regulator 1 Control Circuit
post-96050-0-46396300-1294319597_thumb.p
post-96050-0-20921900-1294325397_thumb.p
UPDATE:
I was drive now 25km on mixed road, everything works and no warning lights ON. Even no smell of burned plastic/gummy after drive.
It is probably worth getting Toyota to check the car over. It is a fairly young car and smells like the one you describe are never good news. Better safe than sorry.
I was receive call from Toyota, they say that they can't find any error or evidence related to problem with warning lights and smell of burned plastic/gummy :eek: :eek: :eek:
They find only one error (probably same that i find) in ECU, but they say that is not related to my problems
They do just regular service @90k.
I don't know what to do now, I can't relax ... any suggestion ? :ffs:
Yes ..... get that in writing from Toyota then if things go wrong it should leave you in a better position, until then enjoy driving your car ;).
Good luck .... Pete.
Well I was pick my car, after short discuss I got write on paper resolution that is everything ok :) (thx for reminding, I was totally forget for that)
However, seems that ELM327 1.3a does not work well, yesterday I was found only one error P0090 and according to Mr.T. they found four totally different errors:
P0088
C1300
C1249
C1201
I don't know what they mean, but if someone already know feel free and write here :)
I will take look tomorrow @ AutoData
P.S.
Service @90k
- Motor oil
- Oil filter
- Activated carbon cabin filter (on my request)
- brake fluid 0,75 !?
- work
total: 3824sek (ca. 346 GBP)
UPDATE:
I was found what this codes represents:
P0088 - Fuel Rail/System Pressure - Too High
C1201 - Brake Boost Sensor Circuit Range/Performance
C1249 - Open circuit in stop light switch circuit
C1300 - Malfunction in ECU
Also I found some Toyota known fixes and bulletins which related to this error and/or engine type:
Known fixes and bulletins 1
Bulletin
Affected vehicles - All models, 07/07.
Problem - Engine malfunction indicator lamp (MIL) illuminated. Trouble codes stored: P0088, P0093. Engine control module (ECM) in limp home mode.
Cause - High-pressure fuel pump internally damaged.
Remedy - Replace high-pressure fuel pump. Install upgraded engine control module (ECM) software.
Known fixes and bulletins 2
Bulletin
Affected vehicles - All models, 03/07.
Problem - Engine malfunction indicator lamp (MIL) illuminated.Trouble code stored: P0400.Engine control module (ECM) in limp home mode.
Cause - Engine control module (ECM) software fault.
Remedy - Install upgraded engine control module (ECM) software.
Known fixes and bulletins 3
Bulletin
Problem - Poor idling. Failure to start.
Known fixes and bulletins 4
Known fix
Affected vehicles
Corolla Verso/CombiVan, engine code: 2AD-FHV (VIN NMTEB16R30R067215).
Avensis, engine code: 1AD-FTV (VIN SB1DD56L40E018674).
Avensis, engine code: 2AD-FHV (VIN SB1BA56L50E060478).
Problem - Sudden power loss on acceleration.Whistling noise from engine.
Cause -Retaining clamps not securing turbocharger (TC) intercooler hoses sufficiently.
Remedy -Replace turbocharger (TC) intercooler hoses and retaining clamps.
I had a similar issue with tc,eng management and abs light staying on.found I could reset it with a Battery disconnect but brought to mr t.
He reported a glow plug fault, could someone check the code if I got it from Toyota.they said the p,ug sometime sieze in the head leading to a head off and e1000 bill. ,,,,,!!!!!!
