Oil Pump Re-Assembly
Missing Lincs
Hello!
I'm looking for anyone who can provide information about re-assembling the oil pump?
Car is 1993 Corolla with 1.6i 4-cylinder engine.
To cut a long story short, garage changed the timing belt, when un-doing the idler pulley they broke the casting on the engine which also houses the oil pump.
They've re-fitted the oil pump into a new housing and put the engine back together but when started it shows a low oil pressure warning light.
The two gears of the pump where placed with marks lined up and in position shown by Toyota's instructions, the garage said they only have a choice of two positions otherwise they don't fit on the crank shaft.
If anyone's re-assembled the oil pump and can give instructions/diagrams or anything we might have missed it would be really appreciated.
