Clica T Sport Inlet Manifold On My Corolla T Sport?
kieranbusak9
will the celica t sport inlet manifold fit onto my corolla t sport? has anybody ever done this?
reason I ask is I have just had the inlet manifold for a celica powder coated and it looks amazing,the only problem is the throttle bodies are at different angles...it was my mistake as I had a moment of stupidity comparing the two! :wacko:
all the mounts are the same apart from the throttle body is at an upward angle on the rolla whereas the celica one is strait and mounted flat to the inlet.
any help would be greatly appreciated.
kieran
No problems at all, tbh I haven't owned mine for very long and its the first Toyota I have owned I am slowly learning though as I change the bits that need changing ;)
As long as all the holes and hoses are there and in the right places I can't see why it wouldn't fit. Obviously you'd have to do some adjustment with bits and pieces but I would have thought it'd be ok.
Not a guarantee though as I haven't done this on the CTS, but I do have some experience with the engine bay :lol:
KP
It was the Throttle Body size IIRC! I think it threw off the idling... can't remember too well though :g:
throttle body im using is the corolla one if it helps! just the celica inlet manifold minus the throttle body is powder coated so i have to use the corolla tb. hope this helps
ive read that thread...it doesnt say much about whether it will fit or not. it just says that the throttle body is different. wheres farhan when you need him!? :crybaby:
i think thats what i will do at the workshop in the afternoon...isn't that hard to remove plus i will use the hondata gasket that farhan gave me. if all goes well i will let you all know! wait till you see the lotus lime green rocker cover :)
cheers mate...i had him on my whatsapp but its gone all !Removed! up! i will give him a ring in a little while bridges don't worry i know him quite well :)
does anybody want a powder coated celica t sport inlet manifold? it looks amazing and i only want a corolla manifold in return! lol
