Eibach Wheel Spacers On A Cts
LOZZA_T_SPORT
Has or is anyone using the Eibach bolt on wheel spacers, on their cts ??
Im thinking of buying a set and using the 10mm spacer either side on the rear, so any feed back would be great .
:eek: how much ££££ lol they will be fine if its ten but that link is for 15mm lol just need longer wheel studs, and is you rolla lowered and have standard wheels or after-market wheels with a different offset?
i dont think you can go to wrong with spacers, just make sure to fit them right.
these are the hubcentric ones yea ?
Yes mate, so it says on the link anyway,
i prefer these ones to the ones that use extended bolts
should be grand, pop the wheels out nicely so it will
im hoping it will push the rears out nicely
i have hubcentric spacers on mine 15 at front and 20 at the back but car is in bits and dont have pics as only had them on a day then car went off the road for the turbo lol. but i had to put my camber right in on the coilovers and buy the camber bolts from fensport and raise the car a slight bit to stop it scrapping but looked ace lol.
scott
20mm each side Eibach hubcentric wheel spacers were ordered today which I will bolt onto the rear wheels
