Looking For Fuse Positions....
Nightstalker
Hi All...
being a bit of a numpty :blush: (I'm not gonna go into detail how :blushing: ) I managed to bust the fuse on the cig lighter on the main dash board and the spare one in the arm rest...
Now I've found the fuse for the cig lighter and for sure this one's busted, but I cant seem to find the one for the powerpoint in the armrest. :wacko:
Does this fuse provide circuitry to both power points???
Also what type of fuse is it? I;ve never had to get fuses like these.... :blink:
regards
Rob
man, I'm surprised no one has helped here... just needed to know the fuse position for the powere outlet on the arm rest as I'm finding it a challenge to find it in the manual... also the type of fuses one needs to replace them... I could go to mr t but I'm sure they'll charge half a mortgage for it....
Hi mate the attached .pdf is for the T25 Avensis and yours may be the T27 model but they may be similar, it shows you where all the fuses and relays are situated on the car.
Pete.
RELAY LOCATION.pdf
Pete.
Thanks for the info Pete,
however the Fuse layout is different on my Vensis. I found a fuse (which is under the glove box) which had blown, I know the cig lighter now works, just need to see if this also fused the aux/power socket in the armrest.... will find out soon when I try the portable DVD player for the kids....
