Vibration When Changing Gear
Xasy
Hello,
I've recently bought 2005 D4D 2.0.
Absolutely love it, but it has started to vibrate when I put my foot on the clutch between gears and when idling in neutral. When actually driving, it's as smooth as silk.
Still under dealer warranty - just wondered if this was a common problem before I approach dealer.
Thanks in advance for any help.
Carl.
dual mass flywheel is on its last legs
sounds like thats the problem.
Hello,
Carl.
hello mate
if engine vibrates once you put yr foot on the clutch then it must be DMF but in case it takes some seconds to observe it during an engine revs being reducing -- this might be either EGR valve clogging or injectors do over fueling as not equalized. CHeers/Igor
