Gearbox Out
pal1
Hi
Anyone done their DMF themselves ? My 03 D4D is slipping a bit but only from cold, clutch is smooth and no noise, so I suspect the drive plate. This was changed 2 years ago along with the DMF, but garage won't help as they tell me its out of guarantee, they also say it might be a leaking oil seal that has got onto the clutch but obviously won't know till the box is out. I suppose they could be right there.
Can I do this on my drive ?
mike
Hi
mike
A member [the name of whom I've forgotten] has done just that so it can be done. It's a tricky job without a pit and parts are very heavy..........
Hi
mike
i helped indie friend change dmf/fairly diff job?lot of stripping down and heavy.i replace with solid conversion and is 1st class .good luck with job .BRIAN
