4.2 Rav4 D4D Coolant Change
tash2007
hi
time for a coolant change on me 02 rav4 d4d - my (US) haynes and (US) factory manuals both refer to petrols, and the haynes says to remove the thermostat to flush through before refilling... where's the thermostat on a d4d? and is it necessary to remove/replace for a coolant change? any gotchas?
Car did have pink toyota long life coolant in it from new until local garage changed it a couple of years ago for some ordinary looking green flavour stuff. I am intending to go back to the long life gear - exactly which do i need? i see red,green and pink Mr T coolant advertised.... :blink: how long is "long life"?
thanks in advance
tash
They used to say "for life" but that seems to be 100k these days.
Just fill it and drain it a few times until it runs clear then drain out enought to get you 50% in (see data sheets).
I would use the pink stuff.
Hi
thanks for reply- for info where is the thermostat on a D4D?
NB The service schedule says change the "long life" coolant every 5 years....
Cheers
Jim
