4Agze Levin
supercharged superstrut
Have a supercharged levin, cone filter 4-2-1 manifold and twin exit cat back exaust, also a hks pfc f-con, 150hp on dyno dinamics, how can i get more out of it before i do pullies
cams, advance timing, port and polish the head, alloy fly wheel or just lighten yr own. i have the pullys on mine make a good bhp gain
I have a 4A-GZE in my 1998 AE111 Corolla. It's pushing out 198bhp but that's with a bigger crankshaft pulley, ERL water injection but the big improvement came by dumping the standard ECU and fitting a standalone Motec M4 ECU. This is not a cheap option but it does use the standard Toyota sensors and overcame a couple of problems that this version of the engine has when you try to get more hoprsepower out of it. I've documented everything to do with the car on my website - take a look at www.ae111sr.co.uk
Thanks 4 the info, any1 know if i should dump my twim exit and go 4 a single? Twin is beautiful, but power wise?
Hi Garry, the car sounds nice, hope to see some photos soon :thumbsup:
Moved from "New members introductions" forum to Levin Forum
Single or twin exit exaust, which is best for my engine?
Toyota originally fitted a single exit exhaust to the ae101 but changed it to a twin exit for the later models.
Aftermarket exausts, which is beter, single or twin?
Whats the craic wit the water injection, how does dat work
