Flip Key Transformation
citam
I changed my regular key to flip key like you can see on pictures
It seems that the transmitter is too far from key cilinder and signal is not strong enougt to start the car. Is ther any solution to strenghten the signal?
I can't answer your question but hope you get an answer.
Any info on where you got your fob from as it looks like a nice mod, if you get it working
Not sure but worth a suggestion, have you taken the transponder chip out of the old key fob and put it in the new one, they are usually separate from the actual buttons.
You probably have but I thought it best to check the obvious lol
Thanks for the link
Transponder chip is integrated with buttons. When I take transponder out of the flip key and hold it closer to the cylinder the car starts.
The only way to get the flip key to work is to remove the chip from the module and install it in the compartment as shown:
Neat looking mod - I might have a go - as I hate getting stabbed in the leg by my key!
Does the plastic unit with the chip disassemble easily or do you need to hack it with a stanley knife?
Thanks for your concern about this, This is a big hlep for us. I really appreciate this post, I got the same problem.
  • 2 months later...
Hi, I am considering doing this, although removing the chip from the remote unit seems daunting. Does anyone know if this would have to be done on the following flip key conversion as you will see the remote buttons are the other way round...
thanks,
http://www.ebay.co.uk/itm/180718655451?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
