Newbie With Yaris Problems
New to DIY J
I have a 2002 yaris, when driven around or below 2000 revs the car judders and sounds to misfire plus when idle it sound rough, i've replaced the coils/spark plugs/lambda sensor/canister purge valve (vacuum valve) and had the air flow sensor check (which works OK) but no joy, it's been mentioned that it could be the throttle body or the fuel injectors.
Can anyone help?
Thanks J
Welcome jon
Try your question on the yaris forum
Thanks for the advice, this is all new to me, as mentioned i've posted my problem on the Yaris forum.
Thanks J
