Mrj's T Sport
S555MRJ
Hi All,
This is my car and the mods that I've done so far:
Just realised I havent updated this since joining lol
Heres what I have done since owning the car:
de-badged rear:
Carbon wrapped the centre console and fitted a TRD gear knob:
Fitted some RED LED's to the centre console:
Fitted some better rear number plate lights.
Before:
After:
Fitted some facelift sideskirts:
Replaced the cabin pollen filter lol :
De-glased the headlights:
Before:
after:
Fitted some footwell red LED lights to come on when doors are opened:
Fitted some red LED's in the boot to come on when the boot is opened:
Fitted some new brake discs and pads all round and new 205/45/16 tyres all round. Lower pro's on the standard wheel, good grip though:
Fitted a facelift front upper strut brace:
Fitted a rear upper strut brace (C-ONE):
Fitted some TTE springs:
Fitted an FK front grille with the T Sport badge:
The almost finished product:
Ive also installed a BMC panel filter but no pics of this.
I am hoping to install the following things and I think that should be it for me:
Modified gear linkage bushes
Rear ARB
Short shifter
Very nice Tsport mate, like all the new lights and the carbon wrapping.
Can I also ask how you deglazed the headlights?
Mine are in need of restoring to clarity (ones a tad yellowish - looks terrible).
Only just seen the replies to this post. I didnt think anyone would take notice seeing as the mods are pretty minor :laughing:
How did you de-glaze headlights?
Hi mate, look further down this post, I will put up details of this
Looks really good, well done
Thanks mate - its small time compared to some other cars Ive seen here and on another forum lol but Im satisfied with the mods so far. Only 2/3 more updates and I think Im done with modding it :D
Cheers, I did the carbon wrapping but it wasnt a good job and its now bubbling and peeling lol may ahve another go at this at some stage :D
cool guy
Thanks Mate
Hi, I had a really bad time trying to find out how to get rid of this glasing. So I tried the following:
The following are details of how to remove this stuff with a product that I used which worked for my own headlights. This stuff in my opinion definitely works.
This is the kit I used:
Now, the product does definitely work, but the same could have been achieved with:
2000, 3000 and 5000 grade sand paper
plastic polish
masking tape
few clean cloths
However buying this was good because everything came in a convenient box for you to go straight at it except for the masking tape.
There are 3 grades of sandpaper in the box (2000, 3000 & 5000)and the process is as follows:
-mask off the surrounding area of light
(Next steps are only to be done for heavy glazing/scratches. If the glazing is not that bad, the wet sanding stages can be skipped)
-wet sand vertically using 2000 paper
-clean the residue off
-wet sand horizontally using 3000 paper
-wet sand vertically using 5000 paper
-Use plastic polish
-buff off the polish after some time
-use the "sealant" which is supposed to protect the lights (and repeat sealant treatment every 3 to 4 months)
Furthermore, the glazing on my lights were so bad that I found it was not possible to remove every bit of it, but its a definite improvement from before anyhow. Here are some before/after pictures:
Passenger side before
Passenger side before - close-up
Passenger side after
Passenger side after - close-up
Driver side after
Definitely a product worth trying.
Also, another product recommended by another member (not sure of his user name on here if he is registered here) is Plexus polish which apparently works just as well if not better...
These are his comments on this product:
"Apparently this plexus stuff was used to sort the canopies on f16 falcons, so I guess it's supposed to be good. It gradually fills in the little imperfections, and the more you do it the better the result. Apparently anyway, time will tell. You just apply it like furniture polish, spray on, leave for a few seconds, rub it in fast, then buff it. I went over all my lights twice with the stuff, and it does appear to have made a difference."
Hope all that helps, and I'm sorry if I have posted the above before on a separate thread. Also, as mentioned, the above is just an example of how it worked out for me, I am not implying it will work for everyone else and you could probably get the same results using a different method.
That's a really good product :) the end result is well worth the work put in, well done.
Thanks S555MRJ.
Good instruction and a good result. Just what I needed to know to cure the Corolla's cataracts.
S2
  • 2 months later...
Just a quick update seeing as i havnt been on here for a while.
I removed the side strips on the doors and rear quater panel and has the sides re-sprayed:
Also, I purchased some used wheels, which I have almost refurbed:
Wish I had a better camera. Anyhow I got the top coat sorted. 2 layers. Now ready for lacquer
Normal graphite:
Sparkling graphite:
1st photo taken without flash, second with.
I recommend BMW Sparkling Graphite, very nice colour especially under sunlight...
I've yet to apply the lacquer and some rubber, hopefully have these on soon.
im deffinatly going to try that on my lights, what do you think of the tte springs..? i want a set of lowering springs but dont want bad ride quality, how well does it ride on the springs not to hard..? thanks
  • 2 months later...
Mate sorry i didnt see this reply till now. The TTE springs are good, they just lower the car and the ride quality stays the same in my opinion.
Just a few details of what I been doing to the car lately:
wheels fitted
New replacement GB plates:
Cold air feed fitted:
Removed the yellow tint on the fogs and just dark tinted them instead:
Alloy footrest plate fitted courtesey of Mr P:
Few bits painted red in the engine bay. Airbox, fusebox cover & Battery clamp:
Short shofter fitted with weighted gearknob, and gear shifter cradle painted red:
Gear stick gaitor removed:
haha thats right corolla, got them fitted now too as you know lol
engine bay with more red lol
Fitted some FK CoilOvers :D
Got the tracking and geomoetry checked and corrected including camber adjustment to around 1.5 degrees.
Sionce getting this done, the car has become much more responsivbe in terms or steering and braking. I would recommend everyone do this atleast once on their car. The place I went to was Wheels In Motion in Chesham, great bunch of people down there and all very helpful. So much so that one of the main guys there talked me through everything he did in the process while he did it, I couldnt have asked for more. I went there on recommendation of another forum member.
This is the front wheel fully jacked up off the floor lol
A lowered E12 always looks great. Congrats and hope you enjoy the coilovers.
Have you changed back to the OEM Tsport rims?
Cheers mate. Yeah I switched back to the original wheels as ive managed to kerb all 4 of the other wheels lol. Plus the woriginals have been wrapped in 45 profile tyres meaning the car sits even lower with these wheels on. But I will try to eventually get the other wheels back on once refurbed :D
How are you getting on with the speedbupmps??? :donatello:
Good question. I have brought new meaning to the phrase '****** other drivers off' lol
every hump, I have to slow right down, and sometimes Ive got so ****** off ive just gone straight through and scraped all sorts.
I think Ive knocked my handbrake cable out of position too, which should be easily fixed.
Just gotta take extra care, its not too bad IMO. I use this car everyday for work and for coilOvers the car is surprisingly comfertable. Not as comfy as stock granted, but comfy all the same to me :D
  • 1 year later...
I have just joined the Corolla world and i that car looks great, +1 for the advise on the lights as mine need a touch of tlc.
Now off to spend some money on my little motor, keep up the good work
Cheers all. Not updated this in ages lol have done a few bits since...
painted rocker cover
Custom induction kit
TTE rep front splitter
TRS Tow strap
Custom backbox
Rear underseat brace from facelift
New tyres
New Battery
JS Performance intake pipe
CAI direct feed from bumper (ported bumper)
How she looks a the mo...
