• 1000's Of Toyota Cars For Sale
    • Join Premium & Save
      Join Premium & Save
    • Review Your Toyota
      Review Your Toyota
    • Save Up To 15% Off For Members
    • Get Your Club Gear!
      Get Your Club Gear!
    • Huge Range of Toyota Parts
AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
toyotaman123
Toyota Landcruiser Amazon 4.2Td 100Series 1998
5 posts in this topic
hi all new to all this , so please bare with me
i bought a toyota landcruiser 4.2td amazon automatic
drove it back and it was perfect
had no problems, and the guy i bought it off has spent loads on lservice repairs etc
however a week on, i
the vehicle starts up straight away with out fail, however it started in limp mode, however if you turn the car on and back on it was fine
recently the car is getting worse and taking longer to come out of limp
i have had it checked by a garage who have come back with a acceleration pedal sensor fault. (cost £540) at main dealers
dont mind buying the part . but just a little concerned if it isnt this.. i have to buy the complete unit.. pedal and sensor. has anyone had this fault in the past
any kind of help would be much appreciated
Share this post
Link to post
check with EGR and clean it from deposits restricting gases passing thru
Share this post
Link to post
Hi
I'm also new to the forum and 100 series cruisers, but ive had similar limp home issues with the same reseting actions as youve had . ive managed to get a code 19 from jumpering the diagnostic connector up above the brake pedal.
Ive been quoted similar prices for a new pedal which nearly put me on my back ( being scottish and tight!)
Any way i resigned myself to the fact i'd need to splash out for a pedal assy fairly soon so i removed the old pedal yesterday for a wee look. the pedal consists of a switch which i stripped and cleaned although it didnt look dirty or corroded. Also on the pedal there is a rotary sensor which i am guessing relates pedal position to the ECU which in turn commands the throttle actuator on the diesel pump to open the throttle a given amount.
Anyway the rotary sensor is factory sealed so i filed off the bead of plastic holding the tin dust cap off then removed the dust cap, this just revealed a PCB board , none of the moving parts were visible. So i filled the entire housing with isopropal alchohol and then functioned the rotary sensor a few times by hand, then i tipped the alcohol out and gave everything a good dry out with a hair dryer .
I fitted the pedal assy back to the car ( without the tin dust cap) and i did 200m today and no limp home mode , but i'll keep you posted on progress.
I am sure the rotary sensor must be used on other toyotas so its worth looking around breakers at the different toyota pedals the sensor is a denso unit .
cheers
greg
Share this post
Link to post
Hopefully a nice fix Greg :)
Share this post
Link to post
Hi, I had a speedo prob with my 1999 amazon, main dealer had no clue and charge me £300 and did not fix, got a cluster unit from manor auto salvage in North Ireland,replaced and now is perfect, they r on ebay, www.manorautosalvage.com, any spares you need and u pay secure thru Pay Pal, rgds Allan ps they are cheap
Share this post
Link to post
