Show
Toyota Landcruiser Amazon 4.2Td 100Series 1998
limp mode problem
  • Please log in to reply
3 replies to this topic
#1 toyotaman123
toyotaman123
    New Member
  • Registered Member
  • 3 posts
  • First Name:alan
  • Gender*:Male
  • Toyota Model: landcruiser
  • Year: 1998
Posted 03 June 2012 - 07:15 PM
hi all new to all this , so please bare with me
i bought a toyota landcruiser 4.2td amazon automatic
drove it back and it was perfect
had no problems, and the guy i bought it off has spent loads on lservice repairs etc
however a week on, i
the vehicle starts up straight away with out fail, however it started in limp mode, however if you turn the car on and back on it was fine
recently the car is getting worse and taking longer to come out of limp
i have had it checked by a garage who have come back with a acceleration pedal sensor fault. (cost £540) at main dealers
dont mind buying the part . but just a little concerned if it isnt this.. i have to buy the complete unit.. pedal and sensor. has anyone had this fault in the past
any kind of help would be much appreciated
#2 igormus
igormus
    Top Rank Poster!
  • Registered Member
  • PipPipPipPipPipPipPipPip
  • 2,841 posts
  • Gender*:Male
  • Toyota Model: RAV-4 ,2007 (2.0 ltr petrol auto)
Posted 14 June 2012 - 02:42 PM
check with EGR and clean it from deposits restricting gases passing thru
#3 gregrsv
gregrsv
    New Member
  • Registered Member
  • 2 posts
  • First Name:Greg
  • Gender*:Male
  • Toyota Model: Landcruiser amazon
  • Year: 2002
Posted 08 March 2013 - 10:20 PM
Hi
 I'm also new to the forum and 100 series cruisers, but ive had similar limp home issues with the same reseting actions as youve had . ive managed to get a code 19 from jumpering the diagnostic connector up above the brake pedal.
 Ive been quoted similar prices for a new pedal which nearly put me on my back ( being scottish and tight!)
 Any way i resigned myself to the fact i'd need to splash out for a pedal assy fairly soon so i removed the old pedal yesterday for a wee look. the pedal consists of a switch which i stripped and cleaned although it didnt look dirty or corroded. Also on the pedal there is a rotary sensor which i am guessing relates pedal position to the ECU which in turn commands the throttle actuator on the diesel pump to open the throttle a given amount.
 Anyway the rotary sensor is factory sealed so i filed off the bead of plastic holding the tin dust cap off then removed the dust cap, this just revealed a PCB board , none of the moving parts were visible. So i filled the entire housing with isopropal alchohol and then functioned the rotary sensor a few times by hand, then i tipped the alcohol out and gave everything a good dry out with a hair dryer .
 I fitted the pedal assy back to the car ( without the tin dust cap) and i did 200m today and no limp home mode , but i'll keep you posted on progress.
 I am sure the rotary sensor must be used on other toyotas so its worth looking around breakers at the different toyota pedals the sensor is a denso unit .
cheers
greg
#4 dervdave
dervdave
    20 stone Victor Meldrew
  • Registered Member
  • 1,273 posts
  • First Name:Dave
  • Gender*:Male
  • Toyota Model: Verso 2.0d TR + Hilux 2.5d D/Cab
  • Year: 2010
Posted 09 March 2013 - 10:24 AM
Hopefully a nice fix Greg :)
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
