Warning Lights On Dash Come On
steveored81
i have a t2d4 2007 avensis estate,
my concern is that my traction control light aswell as my vsc light comes on and stays on after doing some speed
only by switching the car off resets this display of lights on the dash
in the owners manual it does not really explain why
i have just had a new cv joint fitted and the warning lights still appear
ive also replaced the front tyres with a different brand , only discs and wheel bearing to
try
any ideas ?????
Sounds like it may be an EGR valve fault but if memory serves me well, the engine management light also comes on with that. Best to get it read by an independant garage (or mate) and see what it is reporting.
cheers buddy
i will give it a try
genearally the EGR will also throw up an orange EML as well, with the code of P04**
cheers
i read some where that disconnecting the Battery for 20 mins or so would reset things
ive removed the egr valve an cleaned it thoroughly
time will tell
