Stuck! Feeding An Amp Power Cable From Boot To Battery
toyota4me
hi guys,
i'm trying to install a basic amp/sub in my Toyota Avensis Verso. The problem is that even after taking the glove compartment off, i can't find a gap from there to feed the power cable to Battery.
Here are some photos of the glove compartment and whatever is behind it. Any ideas guys of how i can take a wire through?
http://www.toyotaown...lery/album/2179
Any help would be much appreciated.
Thanks!
the only way i did it in my corolla, from look in the engine bay, on the passenger side, should be a wiring loom going through the main bulkhead, make a small hole in the rubber grommet and feed the cable through.
If you need a pic of what i'd done, let me know, and will try and get a pic for you then
  • 2 months later...
Man-bing is correct, work from the engine bay into the cabin. Not the other way round. and sometimes it is easier to reach the engine bay/cabin pass through point from under the car.
