2002 Hiace 2.5 D4D P1126 Code
willy1
engine light on code p1126 fuel line malfunction
car starts and will idle at 1000rpm then it drops after a while to 850rpm then engine light comes on and it wont rev past 2000rpm
start up with a little pedel and you can rev freely with no light. let it idle and you get light back on and no rev up
anyone had problems like this and fixes please
cheers will
check with SCV (suction control valve) mouned on the fuel pump -- it look they are about to die.
besides -- check with fuel filter and if both SCV are found in order then change fuel filter.
