Mr2 Radio Swap With 86120-0R130
J.Solo
Hello.
First, sorry for my bad English.
My name is Jose and I live in Spain. I own a 2003 MR2 and I installed a 86120-0R130 in the car.
At first I had problems with the sound because pin 8 of connector CN700 on the new radio is mute and the car was the trigger of the auto antenna.
Deriving the cable to the cable car for a new antenna adapter like this:
The mute's problem was solved.
Now radio and cd work.
To use the USB connector need PT546-00120-US cable like this:
Well, my big problem is the bluetooth. The bluetooth menu does not appear in the setup.
I don't know if is necessary to connect something through connectors CN800 or CN801.
The unit includes bluetooth? Does anyone know if is necessary to connect an external module to work? What connector is necessary to plug? Will it work if I adapt a microphone?
I hope tips and suggestions.
Thanks.
  • 1 year later...
