Repair And Cleaning Of The Reflector Avensis
madmax12
Hi I would like to share with you my knowledge, especially that avensis have headlight problems.
remove the screws that holds the glass case,
heat gun is required to do this,
heat link between the glass and the case until the glue lets off
after warming up with a little force separate from the case and glass
you can wash the dirt from the entire glass inside and outside whit a sponge and dish soap.
Do it very gently not to scratch it
rinse with distilled water because it does not leave stains and dry air from the compressor
frame covered with silver, we can only flush, do not touch, rub because descends
unscrew the lens
biggest problem is the mirror lens that is burning out
repeat the process starting from the end
if you have any questions, we are happy to answer and help.
